Interrupted SD transfer?
nuguluke
I keep getting notifications to transfer files to my SD card (which has 18gb of free space) but whenever I try to transfer files it shows an error message saying that the transfer was interrupted? Would really appreciate it if someone knows how to fix this problem.
Tags (4)
13 REPLIES 13
Facez3
thank you! : was the problem!
Bye
Swager
I deleted all the images which was there in the folder
Internal storage/DCIM/Camera
But still the problem of transfer intrupted is there..
Plzz help......my memory card is of 32gb(not sony)
kiko66613
Go to your phone right now, check this path using a file manager (highly recommend using File Commander as this is the only file manager of the Z-series that can write to SD card under Android 4.4.4))
Check an image there that has a colon ( : ) in its filename. If there are lots of images there (probably taken with Google Camera, Camera360, or Hangouts), just rename the one that has a colon in the filename. If the problem is still there, rename the long filenames to shorter ones and make sure to remove characters like colon (:) and semi colon (;) if present.
dandiasm
Try tranfering different kind of files first...
I've selected only apps, it worked, then I've removed some media, as kiko66613 has suggested.
It was a new 16GB Class 10 SanDisk card, I've used to have a Samsung 4GB and it has never happened.
