Go to email-settings-signature,you can disable or edit.
Go to the email settings > then tap on the email > scroll down, you should be able to see it
Open the email app > menu > settings > tap on your email > you should be able to see it there
Tap on your email as above.
I'm assuming that you have multiple email accounds within the Email app, if so, there's no other way around, you will have to disable this feature on each email account
