Please, I need to disable the DEMO mode on my phone. When charging the phone or I try to connect to the computer by cable, the Demo turns on and It resets my desktop settings. What do I do? No one has been able to give explanations about it, even in the place where I purchased the phone.
Waiting for a gently reply
My best
If you have a demo unit,the code won't work. You have to replace the device.
This code worked perfectly for my device!!
Thank you very much Friend. My problem solved.
thanks a lot man today i purchased xperia E5 display model and i had this problem thanks for your suggestion
How can i know if my xperia z2 tablet LTE is a demo
hi,
As I can remove the demo mode, try with the code * # * # 73556673 # * # * but it does not work for me.
based on both your posts, you already KNOW that you have a demo unit, so I don't understand why are you asking if its a Demo unit or not.
@LIAM_9 wrote:How can i know if my xperia z2 tablet LTE is a demo
@LIAM_9 wrote:hi,As I can remove the demo mode, try with the code * # * # 73556673 # * # * but it does not work for me.
Thank you so much for help me☺
