GPS not working
maroof
GPS not working
I have this strange problem with my Z1c's GPS. It works with Google maps but doesn't work independently. Like, when I carry out tests using the built-in diagnositc tool and the Service menu(*#*#77378423#*#*), the tests fail. The Service menu GPS test just keeps searching and never completes it. I tried it outdoors as well. Whereas, as soon as I switch go Google Maps, the location is pinpointed instantly. Would appreciate any help regarding the issue. I'm on Lollipop 5.0.2, firmware: 14.5.A.0.270. Thanks! .
komilAD
I had the same problem after lollipop update: http://talk.sonymobile.com/t5/Xperia-Z1-Compact/GPS-test-always-fails/m-p/973384#U973384
But i didn't do system repair because there is no need for it. Every other applications that requires gps works perfectly fine but only during test with diagnostics or service menu it fails.
15 REPLIES 15
@maroof
Settings > location > Mode > how accurate is it?
maroof
@uliwooly
It's set to "High Accuracy".
maroof
@uliwooly
Just tried it. Same result. Didn't work Slightly_frowning_Face
@alexdon
Are you able to recreate this?
profile.country.RO.title
_alexdon_
No,sorry. Just tested on mobile data on the service tests. It works.
alexdon
@maroof
It'll be wise to repair your phone with PCC
PC Companion (PCC)
Bridge (for Mac)
maroof
Was dreading this! Slightly_frowning_Face it's a pain to go through the backup and restore bit but I guess I have no other option right now. Will do it and see if it fixes it. Btw, how come Google maps is able to pinpoint the location if the GPS isn't working? I didn't get that part.
@maroof
I don't know why, but do repair your phone and report back, perhaps an app or service it's acting up.
