Hello everyone,
Every time that my Z3c enters the low battery mode, mobile data is disabled as part of my settings. But when battery is charged without restarting the device, mobile data remains disabled until I manually reconnect.
Restarting the device does not work, only going into settings and reactivating the feature. This does not happen with Wi-Fi; it switches automatically off when battery is <20% and automatically back on when it is >20% or on the charger.
I don't really want to keep mobile data on when the battery is <20%.
Is there any solution to that?
My model is D5803 and firmware is 23.1.A.1.28
Thank you!
Well, I tried disabling Wi-Fi before charging the handset and then found that yes, Mobile Data is not switched off, but Wi-Fi remains off, so I had to go back to settings and connect Wi-Fi.
:smileyquestion:Which makes me wonder what do I want to switch on after my handset has reached the "Low battery mode".
So I guess we will have to wait for an update of Lollipop if the developers are aware of the issue, or even if they consider it as an issue. @uliwooly mentioned that it was supposed to be this way...
