Disabled mobile data after charging
Automat-2015
Member
Hello everyone,
Every time that my Z3c enters the low battery mode, mobile data is disabled as part of my settings. But when battery is charged without restarting the device, mobile data remains disabled until I manually reconnect.
Restarting the device does not work, only going into settings and reactivating the feature. This does not happen with Wi-Fi; it switches automatically off when battery is <20% and automatically back on when it is >20% or on the charger.
I don't really want to keep mobile data on when the battery is <20%.
Is there any solution to that?
My model is D5803 and firmware is 23.1.A.1.28
Thank you!
Jake-SonyXperia
I have found that if Wifi is not turned on and only Data is, once you hit the Low power parameters the data will turn off as normal, and once you connect the charger it will turn back on.
So as long as Wifi is off or your Wifi is on but you are not in an area that has Wifi, Data will turn back on as normal.
12 REPLIES 12
@Automat
Are you using stamina or ultra stamina mode?
@Automat
Settings > Power management > low battery mode
Automat-2015
Member
I am using Stamina.
I have already checked Mobile Data on that screen because I want Mobile Data disabled when the battery is <20%.
@Automat
That seems to be how it's intended to work, perhaps @Johan could elaborate more but it seems that you have to manually turn the data back on.
Jake-SonyXperia
Hi Guys,
I have just done some testing and it seems that Mobile data stays off even when the handset has reached full charge. So this must be turned back on manually.
I will do some further testing to clarify however.
Thanks Jake
Automat-2015
Member
If that is right @uliwooly, it **bleep**. Wi-Fi turns itself back on after charging, you would expect Mobile data to follow the same behaviour. Wouldn't you?
It'll be nice to be able to customize that option, let's say it'll disable the data at 20% it'll be great to enable the data once we reached a preset %
Jake-SonyXperia
