Charging dock DK48 bugging when i want to charge!!!
PhaSskivaN
Hi!
I need help. I have Z3 (D6603) and a Dk48 charger.
I was bought around 1 week.It was work fine(a little slow charging) but i know Eu version dont have fast charge function inside.
Last day when i wanted charge my phone with it i was seen the led is pulsed very fast... when i was check the screen i was seen the little charging icon is turn on/off and the battery icon is disappear or appeared.The phone dont chargng.When i use the usb to phone it is work fine without problems.I was read it was any software bug on older androids. I use 6.0.1 (newest atm)
Is it hardware or software bug? Any know solution? plz help!
Tags (1)
PhaSskivaN
I was sent it back to seller, he was payback to me and dropped it to trash ...i think.
I was bought a normal cable from ebay...and its work...magnetic charg is work with it. that dock was have any contact problem i think.But say all from this , they instantly give me back the money...so problem isnt stranger to them..
6 REPLIES 6
@PhaSskivaN
The Magnetic charger it's indeed slower than using a wall charger, that's normal, you might have either a defective charger or the magnetic port might be damaged, contact your Local support regarding the charging dock and/or your phone.
Vitorportolr
Try to use the original wall charger (the one which came with the phone) to power the dock.
I had the same issue. The battery charging icon was blinking (on and off) about 93%. I changed the wall charge of 1A to the Sony 1.5A and it worked.
PhaSskivaN
I have only that cable and adapter witch was with the phone.Last day i was done with factory reset then it was worked fine.
But at this night was started agin.Now I was put in and out many times and the cable too and seems ok.But im still not sure it is contact problem.Or if it is this isnt premium stuff...just chenese trash..This only 1week old not 1-2 year....So i dunno..I keep testing it.:)
PhaSskivaN
Still dont want charge if it is on 80%...so i can drop this charger to TRASH...:(
@PhaSskivaN
GEt it inspected by your Local support
PhaSskivaN
