Bluetooth turn itself off
9link9
Bluetooth always turn itself off.
I,normally connect with Garmin watch at all times. This strange behavior happens after latest update to Aneroid 7. I must restart phone to get back in normal, but, not last for long. The Bluethooth turn off itself.
Anyone got same issue?
How to solve this problem?
29 REPLIES 29
freepoc
Yes, I have the same problem.
Until we get a proper fix from Sony or Google, I wrote a small app to check Bluetooth at a fixed interval (by default every 10 mins, can be changed). If Bluetooth is off, my app turns it back on.
Let me know if you want to use it.
profile.country.PH.title
MarlonUk1
are you on the latest build update? (.378)
try to perform a software repair using xperia companion
jj_laaksonen
I'm experiencing same problem with Z5 Compact and 32.3.A.0.378. I have Huawei Watch and I really want it to be connected all the time.
I have made software repair with Xperia Companion and adjusted all settings that I think might be related to battery optimisation and bluetooth connection.
Still my phone turns bluetooth off many times a day. I have noticed that only situations that bluetooth keeps on are when there is some ongoing activity with phone and watch, for example SportTracker workout active, or Sleep-as-Android monitoring.
I have enabled developer options in the watch and set it to vibrate always when it loses connection to phone so that I can set BT on again
I have tried Auto Bluetooth app from Solar Wooden Robot but it does not work. I'd like to try another app that set BT on automatically.
freepoc
You are welcome to try my program which checks for Bluetooth every 10 minutes and, if it is off, turns it on.  The program is here: http://www.freepoc.org/download/RestartBT.zip
The program sleeps apart from when checking for Bluetooth so it doesn't use many resources (battery etc).
Hope it helps you.
Regards,
Malcolm
9link
My Z5 latest update version is  .376 ,and no further update available.
Barny_Gumble
Hello,
my Bluetooth is always activated at my Z5, because I need it every day (hands-free in my car).
After Update to Android 7.0 Nougat:  When I reboot my phone Bluetooth get deactivated.
I must activate Bluetooth everytime again after reboot and this makes me very angry!
What is the problem? With Android 6 I didn't have this problem.
Akashv0444
In my phone, Bluetooth is working fine.
No need to turn on Bluetooth every time.
Do these things-
First soft reset your phone..then try.
If problem still persists then i would suggest repair your phone's software using Xperia Companion.
If your problem get solved.
Give kudos and accept as solution ☺
jj_laaksonen
Sorry but after software repair and all imaginable battery optimisations this bluetooth problem still persists.
Akashv0444
I don't know what is going on
You can contact sony representive via call.
They may help you.
