Hello guys,
since the latest update (23.5.A.1.291) my bluetooth devices (headset, speakers, etc. tried many) are not functionning normally. Bluetooth keeps disconnecting then reconnecting. I thought it was randomly at first, then I figured it was when my network signal was changing, for example when it goes from 4G to 3G it disconnects (even also when the network signal goes from 2 bars to 3).
Do you have any solution, this is getting on my nerves...
Thank you,
Regards
Thanks it worked in safe mode with no problem, probably an application is causing this issue.
Back in normal mode, when I force stop quick throw for xperia, it seems to work but it keeps rebooting. Maybe it causes the interference, do you know any way to uninstall it?
I did this https://www.reddit.com/r/SonyXperia/comments/2mdmuk/getting_throw_function_to_workalternative/ and it worked.
