battery usage
Pharaon
battery usage
Is this normal usage for battery or its drain
Screenshot_2015-06-30-15-26-50.pngScreenshot_2015-06-30-22-56-17.pngScreenshot_2015-06-30-22-56-05.png
@Pharaon
Charge the phone 100% > boot on safe mode for few hours > report back, I can't see the pictures until they are approved by a moderator
it could be a third party acting up.
13 REPLIES 13
@Pharaon
could you upload your pictures to box or dropbox and post the links here ?
Pharaon
is it normal usage for batter or drain
i want to know because i feel like it barely stay one day with me while other member says it remain for one and half day
Curnow1
Well for it seems its draining to fast. The WiFI shouldn't be such a problem and the screen is only on 10% so its not the biggest problem. You make alot of calls. I think you have some backround apps draining the battery. Small drain from many backround apps can make a really big drainer! Try doing this
Settings > apps > running  , then stop some apps that you are not using
Pharaon
there's no much app running what consuming battery fast mobile data?
and calls duration was like 3 hours
@Pharaon
WiFi was on all the time, the screen was on quite a bit, network coverage it's spotty and you have other apps that keep your phone awake, whatsapp its a battery hog so, I don't see anything wrong.
Pharaon
@uliwooly
but the wifi were not on all the time actually it been off like 90% the time
so why it show it were on??
is it for mobile data as well?
i off the mobile data and wifi but i dont stop whatsapp from running
i wonder why it show wifi on all the time
@Pharaon
Check the pictures, the wifi bar its solid, which means it was on.
Pharaon
but it was not
is that a bug or something i can fix
