Can you check if the same drainage occurs in safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
i have changed it to safe mood. anyway, can i ask you 1 question? As we can see in the battery usage , the line remined the same for like hours, but at that time my phone was charging. Does the line drop when we dont use the phone, but it is charging?
The line will go up when you are charging.
I see. thz a lot
Anytime.
I dont really understand what does it mean if the percentage drop 5%+ ?
After you have an issue and force shutdown the device,when you turn it back on the battery level will be corrected.
ohhh, thz.
