battery tips
soklinda
battery tips
How to use the battery in the correct way? Any suggestions?
26 REPLIES 26
soklinda
Not really. I have been using it for 2 hours from 96% of battery to 47% right now.
profile.country.RO.title
_alexdon_
Can you check if the same drainage occurs in safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
alexdon
soklinda
i have changed it to safe mood. anyway, can i ask you 1 question? As we can see in the battery usage , the line remined the same for like hours, but at that time my phone was charging. Does the line drop when we dont use the phone, but it is charging?
Tags (1)
_alexdon_
The line will go up when you are charging.
alexdon
soklinda
I see. thz a lot
_alexdon_
Anytime.
alexdon
soklinda
soklinda
I dont really understand what does it mean if the percentage drop 5%+ ?
_alexdon_
After you have an issue and force shutdown the device,when you turn it back on the battery level will be corrected.
alexdon
soklinda
ohhh, thz.
