Hi 9496,
Welcome to the community.
The information supplied above is good advice, however, I would suggest using an authorised repair agent to do the replacement and source the appropriate parts for you.
They are equipped to perform this repair and are able to keep the phone's water resistance rating.
Please use my signature below to find correct contact details for your country.
Hi 9496,
Hi 9496,
I am not sure if you managed to find the number, if not please use the hyperlink below.
I hope it all works out for you.
