BATTERY ICON
ARJUN_SINGH
BATTERY ICON
XEPERIA'S BATTERY ICON used to be the Best among all smartphones. I wish they return with previous Battery Icon (Horizontal Battery with % inside)
ARJUN_SINGH
Thanks for your efforts to help. Our aim is to bring this to Notice that some goods things that made sony stand out from the crowd has been unfortunately removed. In simple words we want sony to bring back Battery icon with % inside from Lolipop and Marshmallow. That was just Superb. Also, one step has been unnecessarily increased to Turn ON/OFF mobile Data. Keep it simple and fast like Lolipop and Marshmallow.
Tags (1)
8 REPLIES 8
ytheekshana
 Yap. I too liked the previous battery icon. New one is worst.
Jonas
Hello everyone!
There is no setting in the phone to change how this icon looks, what you can do instead is either to remove the battery icon or remove the percentage icon, or only have the percentage being shown the phone is charging.
To do that go to Settings > Display > System icons, unmark Battery and/or Battery percentage. If you want to have the percentage only show when the phone is charging you need to enable the System UI tuner in the phone.
Drag down the status bar twice with 1 finger or drag it down once with 2 fingers. Press and hold the small gear icon in the top right corner until it starts spinning > hold it for a few more seconds and then let go. A new menu is now available in Settings of the phone called "System UI Tuner, here you will different settings for example, the status bar.
To remove System UI tuner from the Settings menu, open up the menu and tap the 3 dots > Remove from Settings.
I totally see your point so I will make sure to forward this as user feedback, do note that I can't make any promises that this will be changed. Slightly_smiling_Face
I wish both of you a great Friday and a great weekend!
ARJUN_SINGH
Tags (1)
ply17410
Wow ... if loosing battery icon with % inside is what happens with Android 7, I'll definately avoid installing it.  Thanks for the heads up warning!
Bob H
Minneapolis, MN
USA
adamlee2014
Xperia x range has best battery icon, I love it, hated the old ugly one ever since kitkat
Jonas
You're welcome! Slightly_smiling_Face
You can also get in touch with your Local support team and leave this feedback to them as well.
YarnaaLi
Let's try this reply again 🤦🏾‍♀️ you have just saved me, I couldn't figure out how to turn off the percentage symbol and it was annoying me lol.
Jonas
Hi @YarnaaLi, welcome to our forum! Slightly_smiling_Face
I'm glad to hear that you found the answer helpful and that you now can see the battery percentage again!
Have a nice day and let me know if there is anything else I can assist you with!
