hopefully the problem won't occur again.. I'll keep you guys updated if sth ever happens again
Just to clarify, it does rotate while using apps, like youtube, maps, Gmail, etc?
But it won't rotate from landscape to portrait either though... And the dock is the magnetic charger right? That means I should download a special app for the rotation?.. Because it did rotate earlier though, even when Not using a dock
