Auto Rotate Problem
NirmalSitaldin9
Auto Rotate Problem
Hi guys, I recently noticed that my screen doesn't respond to go on landscape mode when I tilt the phone.. Auto-rotate is on, I never experienced this before.. I saw that other ppl also had this problem, some with the update.. What can I do? Thanks in advance Slightly_smiling_Face
NirmalSitaldin9
Hey guys, I rebooted the phone till it vibrated 3 times and now it works again Slightly_smiling_Face hopefully the problem won't occur again.. I'll keep you guys updated if sth ever happens again
8 REPLIES 8
Phy
Legend
Legend
It will only rotate from portrait to landscape if you use a Dock or a different Launcher.
@NirmalSitaldin98
Just to clarify, it does rotate while using apps, like youtube, maps, Gmail, etc?
NirmalSitaldin9
@Phy Hi, thanks for the quick reply Slightly_smiling_Face But it won't rotate from landscape to portrait either though... And the dock is the magnetic charger right? That means I should download a special app for the rotation?.. Because it did rotate earlier though, even when Not using a dock
NirmalSitaldin9
@uliwooly No it doesn't.. And that's the problem, it used to but all of a sudden it doesn't..
Phy
Legend
Legend
Test the phone while on safe mode
NirmalSitaldin9
NirmalSitaldin9
Thanks btw
Phy
Legend
Legend
Not a problem.
