Audio settings forces to close
mel22
Audio settings forces to close I'm not able to use the equaliser
mel22
I already fix it but thanks for your help, I went to audio settings, force to stop, and clear data, thanks anyway
4 REPLIES 4
Phy
Legend
Legend
boot on safe mode and check if you experience the same issues.
How to boot on safe mode
How to boot on safe mode on Lolipop
1. press and hold the power key
2. once you get the pop up menu
3. press and hold "power off"
4. Boot on safe mode should become available
Christofer
Hi @mel22,
Have you been able to test your phone in safe mode as Phy suggested?
mel22
Christofer
Great job, and thanks for letting us know! Slightly_smiling_Face
