No that’s wrong with Doze you have to leave your phone be no touching or moving it I believe it use motion detector for activating doze mode, and it´s google who decides what’s allowed to disturb, you cannot choose which app.
Se here
http://www.androidcentral.com/inside-marshmallow-what-doze-how-do-i-use-it-and-what-does-it-do
For me that’s a big fail and i will not upgrade to MM for now.
/Conny
Doze is working only when phone is locked, and screen is off.
But what about battery saving when you're using your phone.
Stamina mode was working really good, and allowed you to save good amount of battery.
I updated my phone yesterday, and only got about 3,5 hour of screen time.
I was able to get 5,5 - 6 hours of screen time with stamina mode on, low battery mode at 20% and queue background data.
Now all of these features are removed completely, and doze doesn't save power consumption when you're actively using your phone on daily basis.
Hi battery stamina mode not working when you using your phone. its works only if your phone is not working.
Then u can do the same quite thing with Doze
Application - Settings - Avanced - Battery Optimization - Switch to ALL APP and for every app U don't want Doze, you can click on Dont' Optimize and so on viceversa
I can say to have more battery with more apps on the ground
Doze is a Stamina Mode made by Google and so every producer can have it by default without building other battery saver
More or less are the same things
Now is up to Sony how combine two things without having bugs in notifications
