Can be used already the 512 GB capacity SD card since any system upgrade?
Hi @elfeledhetetlen, welcome to our forum!
In the device specifications it says "Max capacity of external slot Up to 512 GB", so it should work just fine with a 512 GB SD card. The website still says 400 GB though, but I trust the specification sheet that I have more than the website!
In general, the max capacity is tested with the biggest SD card on the market at that time and in most cases, it works fine with a bigger one, but we can only 100% guarantee what the device is actually tested with (does not apply in your case though, but for older devices where it says for example, 32 GB).
I hope that answers your question!
Hi Jonas,
Ok, now I dare to buy a 512 GB card because it should work fine with the device.
Thanks for the answer!
