Hi there!
When I make a call and activate the loudspeaker mode, my interlocuter does not hear me. The same happens if I plug in my sennheiser precision cx 300-ii earphones. When I open a different app (a messanger, for example) I am able to record a voice message even with the earphones plugged in.
Thank you for your reply in advance.
Just to clarify, the issue is when you are using headphones and then switch to loudspeaker?
@uliwooly
Thank you for your reply!
The issue is when I use a regular phone app or Skype + when I either 1)use loudspeaker or 2)connect a pair of earphones without a mic. I tried it with apple earphones (they have a mic) and people can hear me very well.
the problem is I already tried it:( the regular phonecall app still has the same issues in safemode
Are you willing to repair your phone with XC?
thank you! I will try this for sure
@uliwooly Hello. This did not work for me:( the problem is still present. any other ideas?
Hi. I have the same problem. I can't hear or hear very poorly if I talk via built-in microphone. In doing so, the Xperia testing utility records the sound.
