XZ1 Compact - Battery Drain with WIFI
profile.country.IT.title
aerofanIT
Member
i have an issue with my XZ1C (Italy,last official firmware, no root).
I bought it at the end of October 2017 and really like it.
Till half of January everything was ok.
Starting from about that date, i noticed an issue with battery and wifi.
If my phone is on and i connect to a wifi, i see a battery drain rate about 6%/hour.
If i reboot the phone (leaving wifi on), everything comes back to normal (less than 1%/hour).
(Tested with two different routers)
No problem with 4G.
It happens to other users, too (see xda forum).
Is this a known issue?
There is/will be a solution?
Thank you.
10 REPLIES 10
aerofanIT
Member
Hi guys,
on  february 23th, i tried to see if Play Store in XZ1C was updated.
(play store, setting, tap on version)
It wasn't.
Tapping on version, it downloaded last version (8.9.24)
I rebooted the phone.
Battery drain on Wifi seems reduced (with my two modems) or maybe solved.
I'm monitoring the situation and i'll let you know.
RANDOM MAGIC:
*** Other users did the same thing, but battery drain wasn't solved ***
*** XDynamite's battery drain seems solved without do any action by the user ***
