- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Weak WiFi
Translation via Google Translate:
Right ! You buy a smartphone of more than 4 thousand reais that does not work the wifi in the correct way ... I have a competitor j7 Samsung that inside the backpack works better and further, and it costs 700 ... Is there something wrong ?!? Please fix this ridiculous bug in the system, no need to save battery, just need to work the wifi in the correct way, ah and there is one more thing, error Google camera, and do not let 360 ° photos, if not to leave use third-party apps, at least develop apps to hit head-on ...
Certo ! Você compra um smartphone de mais de 4 mil reais que não funciona o wifi da maneira correta... Tenho um j7 da concorrente Samsung que dentro da mochila funciona melhor e mais longe ,e que custa 700... Será que tem alguma coisa errada ?!? Por favor ,arrumem esse bug ridículo no sistema ,não precisa poupar bateria ,só precisa funcionar o wifi da maneira correta ,ah e tem mais uma coisa, camera Google da erro, e não deixa fazer fotos em 360° ,se é pra não deixar usar apps de outras marcas ,ao menos desenvolvam apps para bater de frente...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
for wifi fix
Follow the steps below and report the result to me:
1 - factory reset router and Re-Configure your router again.
2. Reset Wi-Fi network settigns:>>>Go to Settings -> Network & Internet -> tap on the 3-dots icon on the top right corner -> Reset network settings -> Confirm by tapping "RESET SETTINGS"
3. Reboot your phone.
4- Repeat step 2(reset Wi-Fi network settigns)
5. Now connect to Wi-Fi.
Make sure you tell me the result.tnx
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same problem with my premium z5 is it already the range wifi?
yo tengo el mismo problema con mi z5 premium es asi ya el rango de alcance wifi?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
We used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
