i'm from china,
sorry about my english.
so many people face this problem,
the touch screen seems not so funtional,
i find it's a VERY LARGE LAG in fact
in the vedio below, at 24sec, you can see
a short line i painted is not displayed immediately
when i paint next row, it displayed
I really don't see it..
in the gif i post,
focus on row 4, column 5,
i touched the screen there, but no line display
and when i touch next line, it displayed
I still don't see the problem, install AZ screen recorder > follow my test steps > start recording the screen when you test the touchscreen
I don't understand what are we supposed to see on the video
You can also contact Sony directly >>> Local support
Based on his video, around 00:22, 4th row most right dot/line, he tapped it but not registered. However, the following tap register again. Then around 00:28, on the 7th row, it happened again.
I wonder if this issue only found on dual sim variant. Maybe can try a software repair via Xperia Companion.
Yes, you are right, I mean that is the phenomenon
the phone has been returned to sailer
Now I recall, the first day of the phone just seems to be no problem,
after upgrade the system, the next day I found the problem
Now I bought one again, because I still liked the phone
Does the new one seen to have the problem asewell or not?
new phone arrived,
also has problems,
i find a new method to test this problem
paint short line like this,
you do not to paint very fast,
you could paint lines between a 1second interval,
you will see, sometimes the line just painted doesn't display
and when you paint next line , the prev line displayed
