Smart Lock empty after update
KiwiNL
Today I had to update the Android software on my 10-days old (new ;)) telephone. Since the update the Smart Lock option doesn't work anymore. When I tried to figure out what was wrong I discovered that the Smart Lock screen is empty. The options I saw before are gone. So I cannot set Smart Lock anymore. Am I the only one with this problem? Does any of you know how I can fix this?
136 REPLIES 136
Jann6370
Since I installed the new update yesterday, the smart lock on my phone is just blank, all my trusted places have disappeared, can anyone tell me why!
Gungan1
I can confirm I also get this bug.
Turning off Trusted agent before every restart, then turning it back on after boot is the only solution at the moment.
I have read that it is a problem on all makes and models though.
My wife's Pixel 2 is running 8.1 Oreo, and does not suffer from this problem. I can only hope this bug has high priority for our 8.1 build.
Damo_
Shoebox
I was hoping the new 47.1.A.8 49. update would cure this but unfortunately not, got the update this morning and enabled smart locks again but within 2 hours it had failed as per before.
AlanHayward
Same here, Smart lock just gives me a blank screen. I'm not factory resetting it Sony, that seems to be your answer to every problem posted here! If it's that simple to work tech support, can I get a job please?
I'm very dissapointed with this 'flagship' XZ1 phone. I won't be buying another Sony mobile!
Shoebox
Perhaps I was wrong, smartlock has been faultless for 2 days now.
XA3112
Translation via Google Translate"
Reboot helps well, in any case, I go and there is empty after restarting all the rules, but the problem is even there.
Перезагрузка помогает ну мне во всяком случае, захожу а там пусто после перезапуска все норм, но проблема всеже есть.
verycueto
New
Hola yo tengo el mismo problema
 Hello, I have the same problem
GT
Andrey00384
Explorer
Yes
Jaanz
Hi
I have a same issue with XZ1C after update and I can confirm that disabling earlier mentioned feature, rebooting and enabling it helps.
Let's see how long it works.
-Janne
Edit: XZ (not 1) doesn't have any issues
