Slow motion video issue
asmois
 I have issues with slow motion video the resolution is very bad and the light go very dark and video quality is very bad but if I use normal video is perfect  so this normal with slow motion feature or i have problem with camera
14 REPLIES 14
profile.country.PL.title
najodleglejszy
@MarcoA1979 in sunlight the video quality is fine https://vimeo.com/224904535 https://vimeo.com/224979101
Final2009100
Did you solve the problem i have same problem... If you slove it can you tell me how that is my WhatsApp number 00905338854008
Tags (1)
profile.country.PT.title
NunoSEN2
Hero
Hi @Final2009100;
As @najodleglejszy said there is no problem, Super Slow Motion needs good light to work and even with good light it saves at 720p so its natural that the quality it's not as good as 1080p or 4K recording.
Final2009100
So that is normal i don't have any problem right
azzido
Enthusiast
Yes that is normal.
This 960fps produces laughable results in every other that perfect lighting conditions. In perfect sun lightning still it will look regular at its best especially on big 65" screen (in terms of quality because slowness effect is very good).
The quality wise it looks so crappy in most of the conditions due to prehistoric 720p low-res combined with abnormal zoom and noise which makes results even worse and shaky if you capture it from hand.
4K is much better.
For the time being I recommend to avoid 720p mode to avoid disappointment. XZ Premium seems to cone with half-baked beta solution, hopefully we will see 960/1000fps mode in 1080p soon at MWC in Barcelona without this abnormal zoom and noise issues. The point is it should be implemented like this from the very beginning.
