Slow motion video issue
asmois
 I have issues with slow motion video the resolution is very bad and the light go very dark and video quality is very bad but if I use normal video is perfect  so this normal with slow motion feature or i have problem with camera
14 REPLIES 14
profile.country.PL.title
najodleglejszy
slow motion videos require much stronger lighting than regular shots because of very fast shutter speed. also from what I read, XZ Premium records 960 fps slow-mo videos in 720p, which, while isn't really "very bad", can differ noticeably from videos shot in 1080p or 4K.
profile.country.PH.title
MarlonUk1
yes just like @najodleglejszy said,. Lighting is the key...!
Lord_viridis
Outside lighting is the best, electrical lighting tends to pulse as the fps is faster than the electrical pulse.
Chillcirachas
How to fix this, hardware problem?How to fix this, hardware problem?
Help fix this issue
najodleglejszy
Help fix this issue
as said above, the super slowmo mode requires very good lighting conditions in order to look decent. nothing can be done about it.
MarcoA1979
Same Problem, have you solved it? If. Yes in wich way?
najodleglejszy
@MarcoA1979there's no issue, the super slowmo mode simply requires very good lighting conditions because of fast shutter speeds used.
UGLYDOLL
Seems fine to me but you really do need to use proper sunlit lighting, as shown here
https://vimeo.com/225943307
MarcoA1979
Thanks for your answer @najodleglejsz but can you telo me if,  in good conditions of light, the quality of slow_motion is same or lower than the normal camera? Mine is less performing, even if in good light conditions!!!!
