My husbands xz2 has developed a flaw where it constantly talks to you about what's on the screen and the device is not responsive to touch screen scrolling and selection. I have the same model, both upgraded in June this year and mine is fine. This happened overnight, with no explanation. Does anyone know what it is and how to stop it?
Many thanks
That sounds like a Screen Reader has been activated.
I don't have the same phone as you but the setting should be in Settings - Accessibility - Screen Readers, and either Select-to-Speak or TalkBack must be activated.
If they are then turn them off.
Hi @CPayne, sorry to hear about this.
As @Tizer wrote, it does sound like the Talkback function has been activated and the device works a bit differently with this function activated, for example, you will need to double tap instead of single tap and use two fingers on the touch screen to scroll/swipe.
To deactivate this function, follow the steps below.
I hope that helps!
