I did not do anything. this is the default state.(4K seen at AIDA64) Even if I open a video in 1080p, the screenshots resolution 4k
How to make the screen always 1080p?
No.I buy device 3 Day ago
It is normal, aida64 has always detected the correct display of 2160p on xzp, and screenshots are also 2160p. They key point though is that the render is 1080p that is being sent to the device display.
So, yes, what you are seeing is normal.
but my device is getting so hot and I think that's the problem
In addition, the photo is displayed as 4k in Photoshop CS6I have no problems with my 4k. The problem is related to heating the device. Do you have a solution for this? I think the problem is 4k resolution, so I hear that I have to open this thing. Maybe the problem is something else. (instagram appears while surfing the internet, the device is playing at 50 degrees, 41 degrees) Is there a solution for warming up?
