Constant red light on the front side of the phone
Sailor1
I bought this phone 2 days ago .. I'm noticing there is a constant red light right side of the Sony logo (in the sensor area i suppose). No I'm not talking about the led notification light. Can anyone tell me what's wrong with my phone?
24 REPLIES 24
Bellatrikz
Guys just got my xz, funny thing is got a dim red light on the top right side of it, next to the ear speaker on the right... Won't seem to go of unless the screen is closed
adamlee2014
This has already been discussed in another topic. Do you have adaptive brightness turned on under display settings? Try turning it off and the light will then go off.
Korben-Dallas
Indeed, this has already been discussed. However, the conclusions made in those previous discussions (brightness sensor?) strike me as highly illogical. Why would a brightness sensor need to emit its own red light?
And no, disabling adaptive brightness has no effect on this light - it does not go off if you turn off adaptive brightness.
My guess would be that this is an IR LED providing illumination for an IR proximity sensor. A portion of the spectrum it emits is visible as dim red light. And it has nothing to do with adaptive brightness at all.
Sunking1011
It's so the phone can detect when you put it against your ear and thus switch the screen off. All phones have this sensor, some are just cranked up a bit more and become visible. My old, old iPhone 4 has a visible red proximity sensor and did from brand new.
Bellatrikz
OK so I already figured that out with the adaptive display so now what do I do in the sun, any patch solution
adamlee2014
When I turn auto brightness off the light also goes off. Enable auto brightness and light comes back on. So I would say it's the auto brightness causing the red light. Confirmed on my XPERIA XZ
Korben-Dallas
Now, start a telephone call and you will see that the red light comes on again, regardless of your auto brightness setting. In addition to that, even with auto brightness tuned off, the red light sometimes comes on intermittently for no apparent reason.
Ambient light sensor and proximity sensor in Xperia XZ is the same physical device. I.e. it is the same sensor that serves two functions. Ambient light measurement is a passive function: it does not need and additional illumination by any "red light". Proximity detection, on the other hand, is an active function: it works by detecting IR light emitted by an additional IR diode and reflected by user's skin back into the sensor. This IR illuminator diode is exactly what you see as dim red light.
It looks like Xperia XZ cannot power-manage these two functions independently, meaning that once you enable auto brightness, the entere sensor gets powered up, including the IR illuminator (even if the latter is completely unnecessary).
That's all there is to it.
So, again: the dim red light that you see is a part of proximity sensing function. The fact that it appears to be affected by auto brightness setting is just a purely "parasitic" connection, a quirk of Xperia XZ hardware. (I wonder what's the impact on battery life from this.)
Lord_viridis
It did exactly the same with X and has such a minute effect on battery it's not worth worrying about
Eileenstorm
I woke up this morning and found a steady red light coming from the proximity sensor which I don't think it's normal. At least I didn't realised before... Anyone else with this problem?
100rabh
It's just the proximity sensor.. Don't worry it's normal
