I have paired my XZP with a Samsung Soundbar. When I turn on Bluetooth, my phone keeps on connecting automatically on the Soundbar, even when I don't want it to connect .
What can I do?
It didn't work but I found the solution.
The solution is to disconnect from the Soundbar and then turn off Bluetooth. The mistake I did was that when I was connected, I would just turn off Bluetooth and when I turned it back on the phone reconnected to it .
Thanks for the suggestion though!
Hi @Lazaros_K;
Have you tried Settings>Device Connection>Bluetooth>touch cog wheel next to the name of the sound bar>Forget.
