Bluetooth issue after update
neyzen
Bluetooth is not running proper after the latest update 47.1.A.8.49. I have to reset the phone to activate bluetooth and connect to car system, it runs for that time. I turn off bluetooth during day, but have to reset phone to turn bluetooth on again in the evening. Same issue continue in the morning.
Need help from Sony support.
40 REPLIES 40
Nils_T
Thanks for the tip, Neyzen! I'll try this om my XZ1. Did you find the app causing the problem?
Azatra
Today the update 47.1.A.12.119 has arrived.I fixed it at 13 o'clock. Now we have 20-30.While everything is fine, the connection does not tear Bluetooth. Everything is working.I am very happy.
neyzen
I did not receive 12.119 update, still use problematic 12.75 update. I can confirm that my solution works well, no problem on blueetooth connections for two weeks. I dont know which app create problem but I gave permission to many apps which really need location service like instagram and transport apps.
This also fixed empty smart lock screen problem at the same time.
CMB10
Hi, I changed the bluetooth version to v1.5 back in December and it fixed the problem until last week when the phone software was updated automatically and the problem has returned. I have been into developer options and checked all 3 versions v1.4, v1.5 and v1.6 but problem still exists, phone not connecting. ANy ideas appreciated please.
Damo_
As in my other comment, delete the existing pairing then change to 1.4/1.5 again then re-pair. May need to restart you handset after too.
CMB10
Hi, Thanks for your reply but this has not worked. I've tried all different versions of bluetooth and restarted the phone several times too. Any other ideas please? Thanks
Markos83
Problem still persists with this last update and since my fisrt day of purchase. Cant get conection with car bluetooth nokia ck 1w...
Hughcaresless
It didn't work. I tried both versions, but my PLT wireless headphones did not show up for the option of pairing.
CMB10
Bluetooth issues still exist. Please can someone sugget a solution? I have tried all previous versions on phone to link up with car but since the last phone update a few weeks ago in March I have had no success. Slightly_frowning_Face
Andrew27
That worked first time.
Thank you!!!
