I'm using Xperia XZ Premium
After the update to 47.2.A.10.45 the volume rocker doesn't control the media volume...
How to reverse it.
Or can it go back the old way it makes sense to control the media volume by default.
@SadMan1 wrote:Now when you press volume up/down it controls the ring volume not the media
Play music and try pressing volume up and down... If u haven't restarted after the update, restart now. . if any 3rd party call apps working in background.. stop running it . It should be working now..
what happen when you press the volume button? you should be able to control the media volume
After the restart it was all good.
Thank you, kind sir!
