Try formatting the SD card again, and use Media Go program on your PC to transfer music.
I even use a Class 10 card with my older Z3, I'm sure it's supported in your Z5P. It's also mentioned in official Z5P White Paper:
"This device meets the minimum hardware requirements to support Class 10 / UHS Speed Class 1 Flash memory. Flash memory performance is dependent on the application and task being performed on the device. If you would like to know about your memory card, refer to the technical specifications that came with the card."
Test your microSD using an app called h2test and see if it really delivers what it promises.
