z5 compact estimated battery time problem
epk
After the last update (32.2.a.0.224), estimated battery time shows extremely long time like 32 hours at %30 battery level. How can I solve this problem?
Thank you.
5 REPLIES 5
@epk
That's odd, what if you restart the phone?
profile.country.IT.title
Bhonder
What says the charge graph? Maybe the phone rested a while and, because the program still doesn't know your usage pattern, concluded that the charge will hold for long time.
epk
@uliwooly wrote:
@epk
I tried that but still the same. I also fully charged battery after fully drain but nothing has changed.
 That problem occurs right after the update. There is no problem at previous build.
Jake-SonyXperia
Hi epk,
What time frame does it show before the 30% mark, does it change drastically when it hits that percent?
epk
At %100 it shows around 60 hours. Now it shows 51 hours at %83.
But there is no problem about battery life. The only problem is this estimated battery time.
