Hello!
I have problem with my Z3C. Multi-touch in up display area (about 1cm) doesn't work. I can tap buttons, but not gesture. Also i can't use notification bar in normal vertical position. But it work at horizontal position.
I've installed MultiTousch Tester from Play. And this is result:
1. I've taped one finger at bottom are
2. I've taped one finger at top area
3. I've taped one finger about 1cm from top border. And it was display as 2 fingers tap.
What is it? It is software or hardware problem?
PS Sorry for my english
As this appears to be a potential hardware issue you would need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
