Z3+ camera won't start
Ruggles
So, the first day with my new Z3+ - and the camera app won't even start.  The phone is not too hot, I've tried the Norwegian reset (turn the phone off then on) and the camera app still won't start.  All I get is an error message telling me Camera has been stopped.  Suggestions please?
6 REPLIES 6
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
SophiaW
Enthusiast
Hi Ruggles, welcome to the community!
Before running the software repair you can try clearing the data for Camera by going into Settings > Apps > All > Camera > Clear data. If that doesn't help then follow @Thommo's advice. If the software repair also doesn't help, please then contact your local Sony Xperia Customer Care team - you can click the link in my signature for contact details.
Keep us updated, I do hope the software repair resovles the issue for you.
Ruggles
This didn't work.  I did an update/repair on the Z3+ and now that I've restarted the phone I still get the same error when I try to start the camera app.  Any other suggestions?
profile.country.RO.title
_alexdon_
There is a chance the camera is faulty,so you would need to return the device.
alexdon
Ruggles
So, having spoken to Sony Support here in Sweden the answer is to return the phone.  Can't say that I'm terribly impressed that a phone costing nearly 7000 SEK (Swedish kronor) needs to be returned after less than 24 hours use.
lottso
Im in the same situation I bought the new phone to find out every time u took 4 or more pictures the camera app came up and saidbthe device was to hot which it wasn't I returned it to the store to get a replacement to fine that done exactly the same and the one they had left in the shop done exactly the same on now in the situation of trying to resolve it myself via Sony my friend has the phone and hers is fine which is a bit of a let down.
