Z2 update failed
FlorianT
Z2 update failed
Hello.
I have a problem with my Xperia Z2. I tried to make the update of my device but my computer shutdowned during that.
When I turn on my phone, i have this message "The software updated failed.Make sur that your phone is connected to the computer and try again".
The computer doesn't recognize the phone and the phone shut down after this message.
What can I do? 😕
Thanks
24 REPLIES 24
vluser
Well....That means like 1 Month without Smartphone -.-
profile.country.RO.title
_alexdon_
Maybe they can update on the same day if the device is not defective.
alexdon
vluser
It is like 2 Hours away, so i must make an RMA
_alexdon_
I am sorry,contact a staff member before:
http://talk.sonymobile.com/t5/Welcome/Community-users/m-p/634967
Maybe one of them can help.
alexdon
delamer
The advice that Alexdon gave actually works if you can get the download link:
1.Make sure you charge the phone for at least 2 hours
2.After charging,force it to turn off:
http://userguide.sonymobile.com/referrer.php?region=global-en&product=xperia-z2#!Resetting-your-devi...
3.Do not turn it on,open SUS and follow the on screen instructions repair:
The following link takes you to sony's page that says the software is no longer supported.
Just follow the following link to get the download link:
http://web.archive.org/web/20140718103105/http://www.sonymobile.com/gb/tools/update-service/
If that doesn't work, i'll upload the last version that i have to dropbox or so.
Rock on.   Slightly_smiling_Face
_alexdon_
Just use PC companion instead:
alexdon
delamer
Now that is insulting Alexdon...
Logically anyone who has had this problem has been using PC companion...
PC Companion on three pc's i have tested does not pic up any phone in DFU mode, or i think it is called fast boot in android..
I posted the sollution because i had to find an alternative to PC companion that does pick up the phone, as i do not want to root it or loose anything on the phone.
_alexdon_
Sony update service will be dropped,there is a possibility it won't work anymore.That is why I said use PC companion instead if SUS does not work.But as you said,it does have a lower working rate.And no,I wasn't insulting.
alexdon
maubaptista
Thank you very much, guys!
My Z2 is back to life.
I did it using PC Companion. I charged the phone and started the process from the beginning and the program guided me through the right way.
http://www.sonymobile.com/global-en/support/faq/xperia-x10-mini/update-software/software-update-fail...
When you click "start" under "Phone software update" and click on the repair phone link, the program will ask you to press and hold volume button (I can't remember which one) and the Power key. Then you just need to wait.
Nzadi
Does this wipe your device?
