Z2 Status bar not pulling down
kelly1207
Hi everyone, hoping someone can help.
As the subject says - the status/notification bar (or whatever its called) is not 'pulling down'. I've switched phone off and on a few times. Pressed the little red button next to sim card slot....nothing is working.
Any ideas/solutions appreciated.
Many thanks
12 REPLIES 12
firas_A
I bought xperia z2 2 weeks ago. Just today my phone went crazy. The screen started detecting random touches every where _ghost touches_. I switched it off several times until the problem was solved . But apparently a new problem appeared. Now I can't scroll down the notification bar. I went to diagnostics where I could test the device. I tested the touch input and surprisingly the status bar area detects nothing at all. The screen works responds properly except for the upper most part ( status bar area). So I guess that this is a software problem . I tried restarting the device several times but it never worked. I hope I'll find a solution.
Navz
Hy me too purchased the z2 on the 09 Aug and da same probs notification bar not pulling down just after the 15-20days of purchase....ghost touch and diagnostic tool somtimes show no probs sometimes shows dot dot when I pull a straight line down...
I took to the service centet they advised Blore doesn't have support for z2 service and has to be taken to Delhi will take 10-15days...
I took it back..Sony needs to do something on this or replace the set as I dont wana giv the phone for 15 days and repair it...
I have emailed from here and it has gone to the UK support they asked me to write to Asia support...
I dint expect dis whatever the probs they shud have forwarded tht email to Asia support and asked them to handle....
Please look into this
ThanTin
I think it is the hardware problem . Should be Replaced.
But I ve found out one usefull remedy to gain the nortification bar pulled down.
Your Phone need root access.
In adb command ... just type .... adb shell wm overscan 0,50,0,0
this should retract the top of the display and nortificaiton bar work again.
if 50 not work put 100
Thanks
