Hello,
I am using xperia z2 since a month and from few days camera app is not working properly...When i try to open the app it s not opening as fast as before.it lags for a while and opens. Not only that , in manual shoot mode when i switch from camera to video screen gets zoom and lacks clarity..Whats the problem exactly???..I tried to reset but no use,still phone behaves like that..:(
Perform a software repair using PC companion:
Third party apps cannot write to other directories than their own and cannot write on SD,so you won't be able to hide like that.
That's what I thought to be an application error, used keepsafe on ewery device with JB, now app errors and black useless copies make sense. Kinda forgot that now i'm running kitkat. That setting is a real pain in t** ***. What was a point to lock down all SD functionality when you have just 5GB available on system disk, and making it work with 128GB SD cards that can only store photos and music?
Then clear Camera app data and cache!! Then the problem should be solved unless there's any hardware issue (This shouldn't be a hardware issue)
And that getting zoomed thingy is due to Digital Image Stabilizing (SteadyShot), its not something wrong with your phone or camera!!
That happens because the real image get cropped to make the stability!! Try switching off SteadyShot in options! You'll see that it'll come back on to the real, uncropped image!!
It doesn't make the video to be with a siginificant loss in clarity! You should notice this when playing the recorded video!!
