I see no cellular network after I hotboot a new kernel image with "fastboot boot boot.img".
(When I "fastboot flash boot" it, everything goes as it should.)
This occurs on both .114 and .681.
People say it works just as nice on other msm8974-based Sony devices.
Can I hope that it'd be fixed in later bootloaders?
What is it your trying to do? Flash a different kernal or something else like a recovery etc
I need to test my kernel extensively, with a cellular network present.
When I hotboot any boot image (even directly dumped from the boot partition), no mobile network is visible. Radio log says something nasty about the SIM card being not available.
After I _flash_ the same image, everything begins working OK.
I'm not up to speed on your command fastboot boot boot.img - I'm aware of fastboot flash boot boot.img and I'm also aware of and know how to flash and create a kernal.ftf file - Maybe this is one to take over to XDA and ask there
Seems to be a bootloader bug (at least, hope so), or a new feature/policy (it'd be really bad).
Indeed, "fastboot boot xxx" rather than "fastboot flash boot xxx" speeds up the things a great deal (and backs you nicely if the kernel won't load for some reason).
Not sure if network is supposed to work when you hotboot or not. I would recommend that you contact our developer support in this case: http://developer.sonymobile.com/about/how-do-i-get-in-contact/
Thank you, I'll do that definitely.
