Z1 Display Artifacts
schitaev
New
Hello. Please tell, will suddenly be,  who has any thoughts.
Brought Z1 smartphone show. In fact: broken at one corner of the rear wall + a very small curvature of the hull in the area of the SIM card.
The story is this: fell into the hands locked key graphic to see the model was not possible, after there have been attempts to flash the model S(off.firmware), ended balloon, then went firmware C6902(off.firmware), then it worked.
Now the same complaints on the video image display. Now is the firmware 14.4.A.0.157(bootloader isn'T unlocked, Ruta not). 14.4.A.0.108 and 14.3.A.0.757 artifacts were present. It is suspected that the artifacts are progressing.
Few videos to Express what and how.
Immediately comes to mind the thought that it is time to change the display, but the big BUT. The lintel of the screen is not static spot, and moves together with pictures. Also the white text is smeared by a horizontal line(somewhere entirely, somewhere).
Video 1. Visible artifacts and pulling images/pictures in the middle of the text.
http://youtu.be/YgONAVioS4U
Video 2. Visible twitches images, visible white "comb" on the right, moves together with the image, i.e., if they are related.
http://youtu.be/jbsX0aXgPBo
Video 3. Artifacts are moving together with a picture.
http://youtu.be/pMk6MfVjHzg
Video 4. And again pictures and "chasers" are connected.
http://youtu.be/UZA-o5IRumE
Video 5. Blurry text. The thing that confuses me. Watch on the strip where the text service. Jamb begins with the letters in the word "Будильник". Begin to shift the screen to the left and the right of the casing remains in place - here you want to think that it's time to change the display. BUT. Shift the screen to the right and the right of the frame goes together with word, i.e., the letter"Буд" remain outside of the casing/artifacts.
http://youtu.be/A3IPWeX6uFo
PS: it would be very easy to say that we need to take and replace the display, but unfortunately, the device was purchased from them, and means also on the new display is not there. Try to find the cause.
2 REPLIES 2
Thommo
Genius
If the phone is slightly curved as you say then consider that the GPU has been damaged or the screen cable is causing this
schitaev
New
I want to note that the curvature is very weak.
