hello, I am having problem regarding battery, it is not charging properly it show battery 100 percent then shuts off in 75 percent or at any where in middle and shows it has 0 percent, after a while it starts on any number and work for few hour, unable to see correct value of battery level. Does it need calibration, phone still runs on original firm ware with latest version of kit kat.
These batteries do not need calibration,just make sure not to use any task killers,battery savers etc.
how to identify ?? , or should i repair phone from pc companion ?
You have installed them,you should also identify them if any. Check if the same drainage occurs in safe mode,where 3rd party apps are disabled:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
same problems.
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
