Xperia ZL battery problem
TauanCWB
My Xperia ZL have an strange battery behaviour. It started with a crazy battery indicator, for example, sometimes it is showing 75% of battery, then I start to use some app, and the battery drains to 50%, but right after I close de app, the battery shows 63%. So I've never been able to know how my battery is going for sure. Sometimes it is showing 35%, then I just use some app for a few minutes, the battery goes to 15% and suddenly the phone turns off. But when I reboot it, it is showing 30% again.
To charge the phone's battery, I must have luck, because it looks like the phone choose when it would like to charge the battery. The problem turns worst when the battery drains totally. The battery simply doesn't charge, the phone turns on and off constantly. When I plug the battery charger, the LED indicator glows a weak red light, then the "SONY XPERIA" appears, and then the phone turns off, the cycle repeats if I let the battery charger plugged in, back to the weak red light.
Does anyone here had the same problem with Xperia ZL? Does a simple battery change might resolve this issue?
Thank you!
3 REPLIES 3
TauanCWB
Ok thanks, but if you noticed the second paragraph of my post, I just CAN'T turn on my phone because it's turning on and off repeatedly when I plug in the battery charger. So, the "restarting and resetting" solution is useless to me, because my phone simply won't turn on! Please pay attention to the part I said "The battery simply doesn't charge, the phone turns on and off constantly. When I plug the battery charger, the LED indicator glows a weak red light, then the "SONY XPERIA" appears, and then the phone turns off, the cycle repeats if I let the battery charger plugged in, back to the weak red light."
I will appreciate if someone help me with this case.
Thanks.
12345a
same issue happening to me bro
