Xperia Z5c battery life diminished since 6.0.1 update
XcrossfireX
Have noticed a massive lost of battery life since doing the latest update. Use to get easily a day out of the phone, possibly close to 2 days. Now struggling to get to the end of the working day, with minimal use. ?
32 REPLIES 32
profile.country.US.title
Qatrium
Would you go to Settings -> Battery -> tap on the battery icon -> take screenshots of battery usage graph and the list on consuming apps?
Do that when your phone is around 20% battery and post those screenshots here, you may upload photos when using desktop version of the forum only.
XcrossfireX
Screenshot_20161005-173107.pngScreenshot_20161005-173126.pngScreenshot_20161005-173134.png
AldiWanKenobi
I was also struggling with the battery, until I tried changing this setting.  So far, my Z5Compact has shown tremedous improvement, I hope this will also work with yours:
Settings > Location > 3 dots (upper right hand corner) > Scanning
Disable both Wi-Fi Scanning and Bluetooth scanning.
If that does not help, try this next:
Settings > Wi-Fi > 3 dots (upper right hand corner) > Setting > Keep Wi-Fi on during sleep
Select either:  Only when plugged in OR Never
I hope these helps.
Let me know the results.  I'm curious to know if these settings has the same positive effect in your device as mine.
XcrossfireX
Both WiFi and Bluetooth scanning were already turned off
Qatrium
You have an app called "Addinsight" that is using massive power, even more than the screen. Is that normal?
leventech
My z5 compact battery drain faster after last Update, its not take even 1 Day. Old sw. Takes up to 2 days?
XcrossfireX
So it's not just me then?
Xperiaman007
Same thing on my z5p since the last update and sony doesnt care to fix problems
z5 series has worst software treatmant so far..
AldiWanKenobi
I just want to verify, have you tried this setting:
