I have an xperia Z5 Dual.
Both SIM cards are from the same telco provider. Telstra 4G.
At times it works perfectly. both sims get reception, etc, etc.
Although too often I have a sim that's completely off the air. At the moment it's sim2, but earlier in the day in was sim1. I'm not really sure what's going on. I also get quite different reception indicators on each sim.
Somethings not quite right.
I'm not really a person that fiddles with things, but could I have tweaked a setting that's caused this?
Yes. They are nano sim cards.
sim1 has been in use for quite a while in a couple of previous phones
sim2 is brand new for this phone only
Currently both SIMS are working (always the way), but very different signals.
sim1:: -57 dBm / 28 asu (showing 4/4 bars). Mobile Network Type - UMTS.
sim2:: -101dBm / 6 asu (showing 2/4 bars). Mobile Network Type - EDGE.
For completeness I should also add, that sim2 is my "SIM card for data traffic".
That's not a good coverage, you might want to double check the APN settings and contact your carrier/network
dont wrry all z5 have bad resecption.
i have z5c and the reception is so ppor to a degree where even when i am out the reception is only two lines or none.
Don't assume that its the phone, are you using a protective case? if you are remove it and check the following
settings > about phone > status > signal strength
Also check your with your carrier/network if there are any coverage issues.
