Signal drops after update to Marshmallow
Vadkutya
Hi guys,
I have a massive problem after my update to Android 6. My Z5 compact's phone signal drops like clockwork about every 10 seconds and draining battery considerably. During the night I've lost around 30% of battery life.
Anyone else experiencing this?
11 REPLIES 11
Toolsalival
I have exactly the same problem. I've missed so many calls because of this. Not happy!
UK_Customer
I'm getting exactly the same, my battery life is non-existentsince the update to Marshmallow. My Z5 Compact continually hunts for a signal, the signal bars disappear and then immediately return with a full signal.
Does anyone know if Sony support read these or so we have to raise a ticket somewhere?
This is my first Sony phone and most likely my last.
Syncr0s
I've already posted about this. The best assistance offered by the Forum assistance is to switch preferred mobile connectivity to WCDMA from 4G/LTE.
Since the switch my mobile stability has increased out of sight, and so has battery life. Heat has also reduced.
To me it is a bug in the code.
UK_Customer
@Sync0s, thanks for the interim fix. This has immediately resolved the signal issue and thus the battery life - I will continue to monitor.
Overall this problem is very disappointing from an otherwise excellent phone, having to use 3G on a 4G phone is not what I expected when I made the purchase. Sony might want to think about testing their software before release.
Ram786
i am experiencing the same thing and mobile signals are lost continuously
1> battery life reduce
2> App is stored on sd card error
3> Low Profile battery mode is gone
4> unncessary do not distrub mode is automatically on alarm
marshmallow is to much buggy
Syncr0s
MM is fine, but the Z5 image of MM no doubt has issues.
@try my above suggestion for signal which will also improve battery life. MM has an option under battery called battery saver, which is like a low battery profile. I've set mine to turn on @ 5%, but you can make this higher if you want.
Someone else posted about DND mode, and there is an option for setting a time limit, although it's not in the same section just using the volume down button. Use your inner search and find it.
royalzom
Ever since I've updated to Marshmallow 6.0, my phone constantly has no signal. I have checked with my friends who uses the same internt service provider and he says there's nothing wrong with it. Turning airplane mode on and off like how others have suggested works but it returns to no service within minutes.
sujithj
I have a very similar issue.Till the update my battery & signal was working ok. But after the update my signal keeps fluctuating so much the battery also drains in half the time.I'm using Z5 E6683 on Build number 32.1.A.1.185, When I check sim service state my voice and data switches consantly between 'in service' and 'out of service'. My signal also varies between -75 to -81 and also suddenly drops.To make matters worse I tried to do a repair using xperia companion, but after switching on the phone with volume down and connecting the usb cable it only goes into safe mode and does not attempt to repair the OS. I've have been using the phone like this for over  two weeks. I bought this cos of my PS4, blueray and Bravia w800c. I'm now starting to miss my Samsung S6 edge. Anyone's help is much appreciated...
Syncr0s
Have you tried setting your network connection from 4G/LTE to WCDMA like I suggested above?
