Clicking on the battery graph no longer shows your signal strength and awake and WiFi and GPS. Is this a bug? And also the built in battery saver has just been renamed to stamina mode. Does exactly the same job. Stamina mode used to turn data off when the screen was off! And still the same ugly battery icon from kitkat!!!!
yes...it's absurd!!!!
I agree.
By the way the duration's prevision is faulty too: most of time my dumbphone tells me that it will withstand much more than in real life.
Same problem here, alraedy using 0.235 but still cannot show battery detail graph. The graph just feels weird.
But my Z5C battery is pretty impressive, got 6.5 hours SOT
charging time is fantastic, from 24% to 90% in less than 1hour (original charger)
I fear, that actually this is a really problem, because, does it really charge from 24% to 90%.
Recently upgraded my z3 tablet compact to android 6.0.1 which is the exact same version as my z5 but my tablet has the battery graph still which displays WiFi awake GPS on screen on where as my z5 doesnt
hi, I'm experiencing the same issue with my z5 premium
now even the fast charging is affected, and my battery is draining dramastically
the stamnia mode seems to not working android 6.0.1 is a mistake
they need to correct it as soon as possible
please if you find any solution keep me posted
thanks,
How are you able to get the battery graph on the tablet? I'm using the tablet as well but it doesn't goes into to history graph anymore when i pressed on it.
Sony, what on Earth were your Xperia software developers thinking when they removed the battery stats history details? Bring it back! And bring it back to all Xperia devices running Marshmallow!
