Xperia z5 32.2.a.0.224 6.0.1 battery graph question
adamlee2014
Clicking on the battery graph no longer shows your signal strength and awake and WiFi and GPS. Is this a bug? And also the built in battery saver has just been renamed to stamina mode. Does exactly the same job. Stamina mode used to turn data off when the screen was off! And still the same ugly battery icon from kitkat!!!!
37 REPLIES 37
profile.country.PH.title
MarlonUk1
Battery graph- how long have you been using the device? try to charge it until 100% and use it normally as you would, check it again after a few hours of use.
unfortunately that is how the new Stamina mode is implemented. there is nothing we could do about that
if you dont like the UI, you can use third party app launchers.
adamlee2014
Used for about an hour. Battery dropped from 100% to 94% after unplugging and it's currently been on 94% for an hour. I can't click the graph to see if anything is keeping my phone awake like I could on previous build.Screenshot_20160603-120943.png
MarlonUk1
I suggest you do a software repair using Xperia Companion.. if that doesn't resolve, its probably a bug
adamlee2014
Did a software repair when I updated for first time. So it was a clean install. Will probably fixed next month with an update
Markusenka1
Hy.
I update to 32.2.A.0.224 too and i have a very big problem.
My phone Z5C is very, very hot and very drain the battery. So and the NAVI by Sygic wont start.
adamlee2014
I'm quite pleased with today's battery performance, I unplugged at 5.30 am. I have 2 hours 50 min screen on time with 58% remaining and my flash light has been on for 55 min.
profile.country.IT.title
Bhonder
I can confirm that battery graph does not shows usage details anymore: Sony please bring it back!!!!!!!!!
tomo100brt
I am not pleased with my battery. I have System Android battery usage alot. Even 50%. How to stop that? Reset and software repair did not helped. And this new graph is primitive.
Martin20
yeah its weird why sony removed the individual battery details. poor effort, bring it back please. and the stamina mode is a sham...a fake..and please also let people change the time remaining from hours to days
