Xperia Z3 looses Wifi connection when connected to TV via MHL
FredvonR
Hello,
I recently bought an MHL adapter to connect my Xperia Z3 to my HDTV.
Works fine, except one detail: whenever I connect the Phone to the TV, the Xperia drops its Wifi conncetion.
I noticed this when my mobile data limit was reached after 3 minutes of Amazon Video and my mobile provider slowed down my mobile data speed...
Is this a defect of my Xperia Z3 that I need to have fixed by Sony? Is it a general issue all Xperia Z3 have?
Regards,
Freddy
7 REPLIES 7
xavinux
Enthusiast
Hi @FredvonR
I don´t think this is an issue from your Xperia Z3.
If it is a problem with your device, this should also happen when you are connected to another Wi-Fi networks.
I'm at disposal for any question.
Best Regards,
OndTaOpao
Definitively is a problem with your device.
I've also the cable MHL-HDMI and works fine. Even with wifi connected.
MHL Xperia Z3
Kiiro
Hello,
I have the same problem as FredvonR.
@OndTaOpao can you stream videos from YouTube without loosing your Wi-Fi connection and that without mobile data?
I never tried MHL before and just bought the adapter (from a Market for 24,99€) to test it. Then at home I tried it out, it worked flawless (it even shows that I'm connected to Wi-Fi) , I watched few movies (already downloaded) from the app Sony My Videos. No lags nothing. Then after the movie I wanted to watch YouTube videos, when I open the app the loading symbol shows up and then after a time it loses the connection and YouTube says it's an network connection error. When I open Chrome, it takes a while to load the Google page and when I search for something then I get the same error.
After this I tried all that with a Xperia Z and Xperia Z3+. They can stream 1080p even the Xperia Z. So the only possibilities I can think of is that the MHL adapter is really not compatible with my Xperia Z3 or there is an error in my android version (5.1.1 Build Number: 23.4.A.1.232).
I also tried everything like airplane mode, safe mode, 2 different HDMI cables one is 1,5m and the other 3m, 2,4GHz and 5 GHz Wi-Fi and when I do a speedtest the download rate drops till there is no connection. The only thing I didn't try is a different MHL adapter, because I don't want to spend money on it if there is something wrong with my Z3.
And I also noticed that the Sony TV Launcher doesn't start? I read that it starts automatically. Does that only work with a Sony TV or why?
Regards,
Kiiro
OndTaOpao
Here same firmware (23.4.A.1.232). I bought the cable adapter from ebay.
Mine is working fine with Sony Tv and also with diferent brands.
Now with this cable I already used in hotels when I'm in travel and works very well.
I can say with my steps: Connect the cable to the Tv and after to the Z3, the aplication starts automatically.
Well, the last point for me is that I don't have any issue with wifi connection. I use VLC (which is great when you store the movies in the smartphone), but I also use spotify, youtube, soundcloud... but 60% of the time I use the Kodi which uses the Wifi connection and till now is working great. Slightly_smiling_Face
My guest is probably the cable. But never knows... could be the Z3.
Try to test it in a Sony store!! They normally help you Winking_Face
Joxperia
I also have the same problem, but I discovered something, when you call to this code *#*#7378423#*#* and go to service test, scroll down to TV out test, change the resolution to 720*346 (I´m not sure if this it) and The wifi works fine but obviusly the resolution is bad, I was talking with a man and he told me that maybe can be the hdmi cable(the version).
But I don´t understand why any support member respond this topic this is Really Important!
I´m almost sure that is the cable, because I had the same problem with my old xperia S.
So I´m going to try a new cable.
Sorry for my bad English!
OndTaOpao
@Joxperia With your test I believe that is a problem with the cable.
Your cable don't support 1080p resolution.
You guys need to buy a good quality cable! It's very important.
e.g.
Mine is this one: http://www.ebay.co.uk/itm/331530226954
Kiiro
@Joxperia mine Z3 shows me that the resolution is (N/A), if I change it, it's still (N/A) but my TV shows me that the resolution changed. I tried them all but it still loses Wi-Fi connection.
@OndTaOpao thanks for sharing, I ordered it already and it will be here between 23rd and 26th. If that doesn't work then there must be something wrong with my Xperia Z3. When I get it and try it out, I will update you.
Edit:
I got the new MHL cable today and it works. I'm really happy that nothing is wrong with my Z3 and I'm also really thankful to you @OndTaOpao.
