I think i have met some bugs
m0nki
https://www.youtube.com/watch?v=aCwPYjVwE9U
In the video above , you can see a strange  notification I met.
Also , last night I was capturing photos using the physical cam button suddendly the cam stop capturing photo , all the cam UI acting just like usual except the capture button not working anymore( the UI button or the phycical button) . After I restarted the phone , everything recovery .
9 REPLIES 9
@m0nki
Could you boot on safe mode and also test the screen
settings > about phone > diagnostics > test > test touchscreen
m0nki
Hi, uliwooly I boot into safe mode , run the touchscreen test and obviously done without fails .
@m0nki
so you don't encounter those issues while on safe mode? if you don't then it's a third party app causing this.
m0nki
I think its not just only caused by the 3rd party apps , maybe its related to the specified system and apps , because my old c6602(android 5.1.1) has the same apps I installed on my new z5p and of course my old xperia has installed much more 3rd party apps and I have not seen this before .
@m0nki
just because an app work on a phone it doesn't mean that other phones won't encounter bugs, this is an app that you installed not a preloaded app.
m0nki
so , according to your opinion  , any app that is possible imcompatible with a system  ,  making the UI weird or something else , the only reason we can talk about  is the 3rd apps ? eventhogh the apps working fine on different phones or systems and  there  is not any  responsibility for this  phone ?
@m0nki
if the phone behaves properly on safe mode, which disable any app that you have installed, then it is a third party app acting up.
Lord_viridis
Turn off developer mode and see if it can be replicated..
hspcomputer
Hello, Sony Support. I need to help.
I have the (ca) all Sony Z serials: Z1, Z3, Z5 Slightly_smiling_Face
I now buy the z5 (E6653) And i require my work, the rooted phone.
Now only found method: Bootloader unlocked phones
My phone is original Sim Unlock, and Bootloader unlock allowed: Yes
I unlocked my bootloader, and rooted my phone. I need information help:
1.) what function lost, cause unlocked my z5 (E6653) and lost my DRM-s.
2.) I I for the unlock BL. created a DRM DUMP with Sony Flashtool. the dump is created a 2 files:   "1.TA " and   " 2.TA " is 1: 600,6KB
    2nd file: 221,7 KB size. ask: i can use the dump to restore my DRM keys?
3.) if can not restore via dump, and i sent the sony support my device imei and all info, can sending me the drm files? (i pay the service to sony)
Please help me! iam waiting, the answer! Thank you
my email:
